ingyn
Jan 14, 2021Follower
R6260 wont except serial number
Went to regesiter my new router wont take serial number. Its the number thats says serial number below it
- No1MportntLuminary
Do you get any kind of error messages when attempting to register the modem? Is there a link at the site to use if you are having issues registering your device? If there is try using that link. You might also try contacting support directly.
Are you getting an error message?
What notice is it giving you?
Is this a new router? was it renewed/refurbished/used?
you can check the registration faq.
https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQ
there's a contact in there for fixing serial number issues.
