BudikJgnPA
Dec 19, 2016Aspirant
R6300 affected by Vu582384
Hello, is the R6300 affected by this vulnerability announced in December 2016? thanks.
- Dec 20, 2016
For now you should continue monitor the advisory page in case there is any change relevant to your model as our review continues.
At the time of writing this post your model is not on the known affected list.
mdgm-ntgr
Dec 19, 2016NETGEAR Employee Retired
It's not in the list of known affected models. See the Security Advisory
BudikJgnPA
Saw the list but the R6400 series is affected and the R6300 is older which makes me think the R6300 is probably affected also.
- michaelkenwardDec 20, 2016Guru - Experienced User
BudikJgnPA wrote:Saw the list but the R6400 series is affected and the R6300 is older which makes me think the R6300 is probably affected also.
It is called progress.
If you don't believe Netgear's advice, you can try the vulnerability yourself. It is simply a case of visiting a web page. The instructions around here somewhere.
- mdgm-ntgrDec 20, 2016NETGEAR Employee Retired
