StatManChoc
Jan 19, 2024Aspirant
R6300 Does not recognize USB HDD attached
R6300 Router with upgraded firmware to R6300-V1.0.2.80_1.0.59. WD 16TB HDD attached to the router USB port. Same drive and USB connector works perfectly when attached to a computer but is not recog...
- Jan 20, 2024
microchip8 wrote:
I don't know of any NG routers that support such large disks.Indeed, 8 TB is the biggest I have seen reported here that works.
Netgear's database if compatible devices is out of date and incomplete.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
It mentions 8TB for one router, but that's it.
microchip8
Jan 19, 2024Master
I think your drive is just too big.
- StatManChocJan 19, 2024Aspirant
Is there a Netgear router up to date to accept such a large (16TB) HDD attached to the Router?
- michaelkenwardJan 19, 2024Guru - Experienced User
I have not seen reports that ReadySHARE can handle 16TB drives. Indeed, that size seems to cause problems
I have an 8 TB Seagate with two further USB ports that happily work on ReadySHARE.
The usual advice with ReadySHARE is that it does not like partitions, but I seem to recall one user who did that with a huge drive and it worked.
Remember, if you use ReadySHARE you may have to tweak Windows:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
- microchip8Jan 19, 2024MasterI don't know of any NG routers that support such large disks.
