StatManChoc
Jan 19, 2024Aspirant
R6300 Does not recognize USB HDD attached
R6300 Router with upgraded firmware to R6300-V1.0.2.80_1.0.59. WD 16TB HDD attached to the router USB port. Same drive and USB connector works perfectly when attached to a computer but is not recog...
- Jan 20, 2024
microchip8 wrote:
I don't know of any NG routers that support such large disks.Indeed, 8 TB is the biggest I have seen reported here that works.
Netgear's database if compatible devices is out of date and incomplete.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
It mentions 8TB for one router, but that's it.
microchip8
Jan 19, 2024Master
michaelkenward
Jan 20, 2024Guru - Experienced User
- StatManChocJan 20, 2024Aspirant
Thank for the replies all. Shame it can't support a large HDD.
- michaelkenwardJan 20, 2024Guru - Experienced User
True. But a lot has changed since ReadySHARE arrived. Small, Mb thumbdrives gave way to Gb pocket sized numbers and then to the large TB boxes that are supposed to replace multi-drive NAS Ethernet enclosures.
ReadySHARE wasn't designed for that and hasn't seen much in the way of development since then.
It is a pity that NAS costs haven't come down as quickly as other devices.
I have 8TB + 4TB connected, with space to fill two other USB slots with whatever I like. You can do 16 TB but not with a single device.
