Funduboy
Aug 01, 2021Follower
R6300 firmware : unbrick
Hello
I'm using the router since 2012. Recently ; I attempted to upgdate the firmware and I think used incorrect firmware .
Since then the router stopped working. Only power light is ON. Not providing IP address. Soft and hard reset did not work. Tried all suggestions on google (including 30-30-30 reset). But all attempts failed. Looking suggestion about how to access the router via COM port/USB port and correct framwork can be installed. Did anybody attempt the mentioned by openrouter on r6300 (mine is not r6300v1 or r6300v2) . Any other suggestions ?
Regards
Andy
1 Reply
- plemansGuru - Experienced UserYou can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
