thetimelord's avatar
thetimelord
Follower
Jan 17, 2017
R6300 lost wifi connection and will not connect, light on front panel off, help
my netgear R6300 lost wifi suddenly and won't reconnect, need instructions on how to correct problem
  • Hi thetimelord,
    Try pressing the WiFi on/off button on the right side (top button) then check if the WiFi LED (3rd light from left) lights up.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi thetimelord,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi thetimelord,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
