shwtibby
Feb 25, 2017Aspirant
R6300 Need to find a WAN plug surround
The plug surround for the single WAN RJ45 plug has gone missing. It detached from the inside of the router. Now I cannot plug the male internet service plug into the router. Any suggestions? I at...
- Mar 06, 2017
It went out in the mail today mailed hope it fixies the router for you.
DexterJB
Feb 28, 2017NETGEAR Moderator
Hi shwtibby,
If the device is already out of the hardware warranty period then a replacement will not be an option. You can find female Ethernet connectors but replacing it will be quite difficult.
Dexter
Community Team
shwtibby
Mar 01, 2017Aspirant
Spoke with Netgear Customer support today and they have no ability to source parts for the R6300. I just need the small 'snap-in' support surround for the WAN internet input plug in the back - anyone?
- William10aMar 03, 2017Master
If this the part you want I can drop in the mail for you just leave your address or post box in a pm easy to remove if you access to smd mount rework station and the smd paste solder and you the needed soldering skills it is yours if you want it. One rj45 jack out of a old dsl modem.
- shwtibbyMar 04, 2017Aspirant
Thanks so much for your reply! Any was to send the picture(s) again? - they did not seem to come through on the site. Thanks, Steve
- William10aMar 04, 2017Master
I hope they get there this time if not plase leave a email address in private mail and I send the pictures where you want.
- shwtibbyMar 05, 2017Aspirant
That does look like the fix - many thanks. If you could send it to me below I would very much appreciate it. Let me know on the cost + postage and I will send that to you. Again, Thanks!
- William10aMar 06, 2017Master
