jabba400
Jul 12, 2016Aspirant
R6300 not detecting Ethernet connection
Purchased a second hand R6300 in the hopes of improving connection speeds over an old Belking Wireless G router distributing data from Cable modem. Original setup is Cisco cable modem - belkin router - wired and wireless connections. OK but not flash.
Connected R6300 to Belkin via ethernet cable, and was able to configure netgear wireless 2.4 and 5ghz connections, and use them to connect through ethernet Belkin connection.
Set Netgear internet settings to match Belkin settings (gateway, fixed ip address, dns servers). Unplugged Belkin from cable modem, plugged Netgear into cable modem, all wonderful. Connection speeds wired and wireless all boosted. BUT - still a dead spot in one part of house. Thought "I'll set up Belkin as a bridge / extender, and all will be wonderful". This is where it turns to custard.
Updated Belkin to activate "Wireless Bridging". Looked into Netgear settings and found Advanced wireless setup and turned on access point mode. Lost connectivity to setup, wireless and wired networks. Logged into Belkin and turned off wireless bridging mode, and was able to restore Belkin wired and wireless connectivity.
Performed a Factory Reset on the Netgear R6300. Now can't connect to ethernet / internet from R6300. Home page status has internet "not connected", other devices connecting to Belkin ethernet ports are ok. Executing the "Advanced Setup Wizard", I select my country (New Zealand), then it does a "Detecting the Internet Connection" for a few seconds, then comes back with "Problem Detecting the Internet Connection - IP Address". Selecting any of the options and then entering the device's mac address, still get the "Problem detecting the internet connection".
So now, I have an extremely glamorous paperweight, it seems.
Is there some setting that needs adjustment to get it to recognise the ethernet connection?
Success
Changed WAN setting to "Must use Ethernet WAN" and unchecked the "Use VLANID" and it kicked into life.
IPv6 still set to passthrough.
PCs will connect either through ethernet or wifi no problem.
Try power cycling your cable modem. Another option is to clone your Belkin's MAC address onto your Netgear. This will fool the ISP into thinking your Netgear is the Belkin.
- jabba400Aspirant
Transferred the static IP settings, DNS settings and MAC address from the Belkin to the R6300. Power cycled cable modem and power cycled and connected R6300.
Now have green "internet" light on front of R6300, but Genie still reports no internet. Cable modem shows green on the "link" light.
PC connects to modem admin ok via direct addressing (192.168.0.1), but not via the "routerlogin.net" address.
I seem to recall having to change IPv6 settign to get it to work originally, but changing it from "disabled" to "auto detect" or "passthrough" and power cycling cable modem and r6300 has no obvious effect.
Any other ideas?
- jabba400Aspirant
Success
