Wolfangovich
Apr 27, 2018Aspirant
R6300 Power Adapter replacement?
For a replacement power adapter, I understand it is a 12V 5a, but what is the polarity on the end? Is it Negative inside or Positive inside?
TIA.
- Apr 28, 2018
A quick check of four Netgear adapters I have lying around says positive inside.
antinode
Apr 27, 2018Guru
> [...] I understand it is a 12V 5a, [...]
For an R6300 plain/v1, that seems to agree with the documentation.
(The R6300v2 seems to be more efficient.)
> [...] what is the polarity on the end? [...]
Doesn't the label on the adapter show this? If not, then look
closely at the product label on the router If that fails, then visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Look for "Label". (Also
interesting: "Technical Specifications".)
- WolfangovichApr 28, 2018Aspirant1 I checked all documentation
2 little hard to check the adapter if I am replacing it
3 the router does not show this information, thus the question in the first place
4 checked their entire site, answer is not found on there, thus the question- michaelkenwardApr 28, 2018Guru - Experienced User
Wolfangovich wrote:
2 little hard to check the adapter if I am replacing itLook on the back? That's what I did.
- antinodeApr 28, 2018Guru
Define "all". Does that include the User Manual? Where there's a
picture of the product label? Which shows the polarity of the power
connector?
Are you replacing it because it's defective or because it's missing?
> first place
Is the product label missing from the router?
> 4 checked their entire site, [...]
That's just silly. And you don't need to check "their entire site",
only the User Manual for the R6300.
> [...] answer is not found on there, thus the question
I found it there, following the instructions provided:
http://www.downloads.netgear.com/files/GDC/R6300/R6300_UM_18Jun12.pdf
Look at page 11, "Label", "Figure 4. The label shows unique
information about your router", upper right-hand corner. Some
magnification might help.
It's not complicated. Try a Web search for these keywords:
lead horse water drink
