Wolfangovich's avatar
Wolfangovich
R6300 Power Adapter replacement?
For a replacement power adapter, I understand it is a 12V 5a, but what is the polarity on the end? Is it Negative inside or Positive inside? TIA.
  • michaelkenward's avatar
    Apr 28, 2018
    A quick check of four Netgear adapters I have lying around says positive inside.
