Wolfangovich
Apr 27, 2018Aspirant
R6300 Power Adapter replacement?
For a replacement power adapter, I understand it is a 12V 5a, but what is the polarity on the end? Is it Negative inside or Positive inside?
TIA.
- Apr 28, 2018
A quick check of four Netgear adapters I have lying around says positive inside.
Wolfangovich
Apr 28, 2018Aspirant
1 I checked all documentation
2 little hard to check the adapter if I am replacing it
3 the router does not show this information, thus the question in the first place
4 checked their entire site, answer is not found on there, thus the question
michaelkenward
Apr 28, 2018Guru - Experienced User
Look on the back? That's what I did.
