tdmchris's avatar
tdmchris
R6300v2 connecting smart tv magnavox
I'm trying to connect my TV to wireless. It says to put pin number in the router settings. I can't figure out where to put the pin number when I go to settings.
  • Which TV model?
    Connecting a "smart" TV is usually down to working your way through the configuration screens.
    In general these devices are incredibly dumb.
    If you have a TV with a LAN port, I would seriously consider that option, perhaps with Powerline Ethernet. Much less flaky than wifi.
  • > It says to put pin number in the router settings.
       What, exactly, says what, exactly?  Your audience here can probably
    find a user manual for an R6300v2 (firmware version?) but the
    non-psychics in it have little or no idea what "smart tv magnavox" might
    be, or how it works.  Are you talking about a WPS PIN?  (The router may
    have a WPS PIN which you'd need to provide to the client device, not the
    other way around.  Perhaps: ADVANCED > Advanced Setup > Wireless
    Settings : WPS Settings.)
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.
       Note: "PIN number" is redundant:
          http://antinode.info/complaints/aer.html
  • michaelkenward's avatar
    michaelkenward
    Which TV model?
        michaelkenward
        tdmchris wrote:
        Thanks..finally figured it out..
        Well done. What was the trick for you? It might help someone who turns up with the same challenge.
