thedoctor10925
May 20, 2018Aspirant
R6300v2 "online" night does not light up and no internet
R6300v2 was working great up until yesterday. Today the internet/online light no longer lights up and I cannot connect to the internet. Modem is working fine. Can connect to WiFi but no internet acce...
- May 23, 2018
Hi thedoctor10925,
1. Have you tried changing the cable connecting the modem to the router?
2. You can also try doing a loopback test to check if the Internet/WAN port is working. This link may help out.
Dexter
Community Team
michaelkenward
May 21, 2018Guru - Experienced User
Have you tried rebooting the whole network in the correct order?
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
- thedoctor10925May 21, 2018Aspirant
Thanks for the reply michaelkenward. Yes, I tried the recommended procedure twice.
Still have no access to internet via the router.
- DexterJBMay 23, 2018NETGEAR Moderator
Hi thedoctor10925,
Dexter
Community Team
- DexterJBJun 07, 2018NETGEAR Moderator
Hi thedoctor10925,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
