Brian783
May 24, 2017Aspirant
R6300v2 slow wifi speeds
My r6300v2 is getting slow wifi speeds. I have tried changing the channels and still no luck.
I am using charter spectrum. Internet from isp modem is 67. When I connect over wifi I get 30. Is the any settings I can change to make this better? I already upgraded to the latest firmware. Did a factory reset. Un plugged it and restarted.
Any ideas? Thank you.
Hi Brian783,
Please try re-flashing the firmware of the router then do a factory reset and check if the issue persists.
Dexter
Community Team
- Brian783Aspirant
firmware v1.0.4.8_10.0.77
issue persist on 2.4ghz. i dont use the 5ghz except for xbox360. nothing else i have will connect to it. so i never tested the 5 ghz.
issue does persist on all devices.
wired directly to the netgear router i got 65.95.
wireless i got 33
on channel 1 for 2.4 ghz
thank you
- Brian783Aspirant
i connected my phone to 5ghz. i got 3mbs download speed.
- Brian783AspirantAny ideas
