Rodrimag
Aug 17, 2022Aspirant
R6350 How many devices can I connect
Hi,
I have an R6350 and would like to know how many devices (wifi) I can connect.
I have approximately 30 devices connected at 2.4GHz and 8 connected at 5GHz.
When I try to connect a new one, I normally have issues, or when the router restart, some devices did not receive an IP address and I need to block this device to the others receiving the IP address.
Maybe I have many devices?
Its usually 32 per band. but the R6350 is a pretty basic router. If you can move any of the 2.4ghz devices to 5ghz, you'll do better to even out the load a bit
- RodrimagAspirantSo, it means 32 devices at 2.4Ghz and 32 devices at 5Ghz!!! So if I connect a second wifi router (this r6350 connect a second wifi router by ethernet cable), I can double the devices?
If you've separated out the bands and made sure they're not on the same channel.
but again, its not a flagship router, its a pretty base model one.
While it should support up to 32 devices, if they're higher bandwidth devices, you're going to have issues.
https://kb.netgear.com/24043/How-many-WiFi-client-devices-can-my-NETGEAR-router-support
