rfo056's avatar
rfo056
R6400 - AC1750 Smart WiFi Router Connected No Internet
Trying to understand how this could happen, can only guess for now. Wifes phone Samsung AO2S connecting to router but with no internet access. Kept trying to find problem on phone, turned out that the connection to router was allowed to connect. But router blocked it from accessing internet. The phone is new and has run fine until today.
Everything else connected to router running perfectly.
This has never happened an I'm really surprised to find that maybe the router is smart enough to block malicious activity.
Can anyone help explain this.
I have access to router blocked by all until I go into advanced security an allow them to connect.
Windows 10 Professional v 21H1  OS Build 19043.1165
Router Firmware Version
V1.0.1.62_1.0.41
Using TrendMicro Mobile Security on phone
  • rfo056 wrote:
    ....turned out that the connection to router was allowed to connect. But router blocked it from accessing internet.
    How did you work out that the router is the culprit?
    Have you enabled access control on the R6400?
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Block Access to Your Network.
    Is that what you mean by this?
    Not sure that I follow the language there, but if you have told the router to block all new devices then maybe it is just doing what you asked it to do.
    Why would it block your wife's phone when you have given it permission? Because, from what I read here, Apple and others like to change the Mac address of things like mobile phones. So the next time your wife tries to connect to the wifi, your router sees a new device and tells her to go away.
  • michaelkenward's avatar
    michaelkenward
    Support | NETGEAR
    • rfo056's avatar
      rfo056
      Problem at router was discovered when I logged into router and went to advanced, access control. My wifes phone was Blocked
      I changed it back to Allowed. Then all was back to normal.
      Yes I have Access Control enabled.
      The wifes new phone had been working for over 3 weeks after I got it and set it up for her. Then all of sudden, the router blocked her.
      That's was I'm trying to figure out how that could have happened.
    • rfo056's avatar
      rfo056
      After thought.
      Her previous phone also a Samsung phone had been connected and function with never getting Blocked .
    • rfo056's avatar
      rfo056
      On the phone it was showing connected. Just no internet access.  Wifi symbol on phone was showing with a "!" next to it. In settings it was saying connected no internet access.
