Amarillo's avatar
Amarillo
R6400 - just used Nighthawk to update firmware to v1.0.1.46 and now I have no 2.4 ghz WIFI
I have the Netgear AC1750 Model R6400 (which is not in the dropdown).  It was working perfectly until I installed the new firmware update.
This morning I got an email to update the firmware to v1.0.1.46 using the Android Nighthawk app. I did that.  Then I physically rebooted it by pulling the power plug.
Now I have no 2.4 ghz wifi.  However the 5 ghz wifi is working.  What is the fix for that?
Thanks!!
  • Anytime you do an update its recommended to reset the router. Pulling the plug isn't resetting the router and can actually corrupt it if you're installing new firmware. Try doing a hardware reset and if it still doesn't work, downgrade the firmware and do a reset again.  You can reset it under Advanced->administration->backup settings->Erase.
    Try this and then go to the downgrade step if that doesn't work.
  • plemans's avatar
    • Amarillo's avatar
      Amarillo
      Thanks!!  I ended up doing the factory reset and it seems to be working now.
      Thanks!!
