rickyl
Feb 10, 2018Tutor
R6400 crashing overnight with high SY and high WA
My R6400 (F/W V1.0.1.36_1.0.25) has crashed overnight two nights in a row. After the first crash, I started running two telnet sessions from my laptop to the router (via wi-fi) - one running top and the other running vmstat 1. When I checked this morning, the router was crashed (although all led's were flashing and steady as normal). The only interesting clues (for me anyway) were: 1) top had [mtdblock3] as the highest process and it was at 40% cpu, 2) vmstat showed consistently high SY and high WA, roughly 75% SY and 25% WA (no idle and no user). Also, the run list was only 1 to 3 (except for one time at 39). And, blocked was 1 to 4 when it normally is 0). I don't have any timestamps so I can't tell when this happened. I have a USB drive connected that I use for automated backups and manual storage. I haven't changed anything with the backups and it is possible that one was running when it crashed. The clues point to some type of system/kernel activity (75% SY) and blocked on I/O wait (high "B" number and 25% wait on i/o). Any help or suggestions is greatly appreciated. I had the debug log emailed to me but I'm not smart enough to understand all of it ;-) Thanks.
Thanks for your research and help. I was thinking the same - that it's the internal storage that's failing. It is now occuring at least once a day, randomly. I wonder if there is a way to run something like a chkdsk on the internal storage device? I'd hate to have to trash the router for something that should be fixable.
- rickylTutor
Found some more clues, this time in the mtd17 log file:
<3>[598396.820000] SQUASHFS error: Unable to read fragment cache entry [edcf50]
<3>[598396.820000] SQUASHFS error: Unable to read page, block edcf50, size c43c
<0>[598396.820000] Kernel panic - not syncing: Attempted to kill init!
<4>[598396.820000] [<c00552a0>] (unwind_backtrace+0x0/0xe4) from [<c03ac418>] (panic+0x68/0x194)
<4>[598396.830000] [<c03ac418>] (panic+0x68/0x194) from [<c007294c>] (do_exit+0x68/0x608)
<4>[598396.840000] [<c007294c>] (do_exit+0x68/0x608) from [<c00731b0>] (do_group_exit+0x90/0xc0)
<4>[598396.850000] [<c00731b0>] (do_group_exit+0x90/0xc0) from [<c007cfe4>] (get_signal_to_deliver+0x334/0x36c)
<4>[598396.860000] [<c007cfe4>] (get_signal_to_deliver+0x334/0x36c) from [<c0051320>] (do_signal+0x50/0x5d4)
<4>[598396.870000] [<c0051320>] (do_signal+0x50/0x5d4) from [<c0051da0>] (do_notify_resume+0x18/0x38)
<4>[598396.870000] [<c0051da0>] (do_notify_resume+0x18/0x38) from [<c004eaf8>] (work_pending+0x24/0x28)
<2>[598396.880000] CPU0: stopping
<4>[598396.880000] [<c00552a0>] (unwind_backtrace+0x0/0xe4) from [<c004e2f0>] (do_IPI+0xfc/0x180)
<4>[598396.880000] [<c004e2f0>] (do_IPI+0xfc/0x180) from [<c0487ca8>] (__irq_svc+0x48/0xe8)
<4>[598396.880000] Exception stack(0xc04c9f78 to 0xc04c9fc0)
<4>[598396.880000] 9f60: 00000000 d794f000
<4>[598396.880000] 9f80: c04c9fc0 00000000 c04c8000 c04d4bc8 c04f50a8 c04d4bc0 000260e0 413fc090
<4>[598396.880000] 9fa0: 0000001f 00000000 c0548cb8 c04c9fc0 c004fbb0 c004fbb4 60000013 ffffffff
<4>[598396.880000] [<c0487ca8>] (__irq_svc+0x48/0xe8) from [<c004fbb4>] (default_idle+0x24/0x28)
<4>[598396.880000] [<c004fbb4>] (default_idle+0x24/0x28) from [<c004fd1c>] (cpu_idle+0x40/0x94)
<4>[598396.880000] [<c004fd1c>] (cpu_idle+0x40/0x94) from [<c0008c64>] (start_kernel+0x320/0x37c)
<4>[598396.880000] [<c0008c64>] (start_kernel+0x320/0x37c) from [<00008084>] (0x8084)
<4>[598396.880000] NVRAM LOG 16384 23487240 23503624
FS error: squashfs_read_data failed to read block 0xa96a94
<3>[598396.570000] SQUASHFS error: Unable to read data cache entry [a96a94]including
<3>[598396.620000] SQUASHFS error: xz_dec_run error, data probably corrupt
So all the clues point to data corruption. Question though, where? How do I determine if it is on my USB attached drive or on some internal storage in the R6400 itself?
# df -h
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock3 27.9M 27.9M 0 100% /
devtmpfs 124.3M 0 124.3M 0% /dev
devfs 124.3M 0 124.3M 0% /dev
/dev/mtdblock19 5.0M 396.0k 4.6M 8% /tmp/openvpn
/dev/mtdblock18 57.0M 2.9M 54.1M 5% /tmp/media/nand
/dev/sda2 5.5T 555.3G 4.9T 10% /tmp/mnt/usb0/part2> <3>[598396.820000] SQUASHFS error: Unable to read fragment cache entry
> [edcf50]
I know nothing, but a quick Web search suggests that "Squashfs is a
compressed read-only file system for Linux.", which suggests that you're
looking at router firmware, not data on your external USB device(s).
https://en.wikipedia.org/wiki/SquashFS
> corrupt
"xz" sounds like (some form of) LZMA compression. A "mount" command
should tell you which file system is used on each mount point ("type
XXXX"). Might be informative.- rickylTutor
