abhi_shah
Oct 31, 2022Aspirant
R6400 firmware upgrade 1.0.1.78_1.0.50 from 1.0.0.62 issue
d update is saying successfully applied but it keep showing update available. and see d same versions: upgrade version:1.0.1.78_1.0.50; current version:1.0.0.62
Try updating using a wired PC and web browser...
How are you applying the FW update? Wired PC and web browser, MS EDGE or FireFox is recommended.
Be sure to clear out all browser caches before and after loading the FW file.
After the FW update is applied and the router is back to ready, a factory reset maybe needed and setup from scratch.
