dorlich
Feb 14, 2018Aspirant
R6400 Firmware Version 1.0.1.26 issues
hi all.
just installed new firmware for this device . it broke my internet connection.. VPN connection drops every minute.. soft reset and hats reset is not solving the issue.
anyone with the same problem?
rolling back to 1.0.32 to test
Hi dorlich,
Have you tried re-flashing the latest firmware then do a factory reset? If not, that is something that you can try and check if the issue persists.
Dexter
Community Team
