steakhouse
Sep 08, 2017Tutor
R6400 guest wifi disables regular wifi
I searched the forum but couldn't find a similar case. I have a R6400 wifi router and would like to also enable the guest wifi. But when I do it, the regular wifi on the same band will disappear and...
- Sep 14, 2017
Hi steakhouse,
1. Have you tried resetting the router?
2. Have you tested other firmware versions?
3. Have you tried changing the wireless channel for either/both bands?
4. What is the WiFi LED activity when the issue occurs?
Dexter
Community Team
DexterJB
Sep 14, 2017NETGEAR Moderator
Hi steakhouse,
Dexter
Community Team
- DexterJBSep 17, 2017NETGEAR Moderator
Hi steakhouse,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
