steakhouse's avatar
Sep 08, 2017
R6400 guest wifi disables regular wifi
I searched the forum but couldn't find a similar case. I have a R6400 wifi router and would like to also enable the guest wifi. But when I do it, the regular wifi on the same band will disappear and...
  • DexterJB's avatar
    Sep 14, 2017
    Hi steakhouse,
    1. Have you tried resetting the router?
    2. Have you tested other firmware versions?
    3. Have you tried changing the wireless channel for either/both bands?
    4. What is the WiFi LED activity when the issue occurs?
    Dexter
    Community Team
