Srminnehan's avatar
Srminnehan
Follower
Apr 19, 2017
R6400 in bridge mode
My R6400 is not communicating with the "little black box" of our internet provider... rise broadband. And the second light from the left is not lighting up. I first thought it was a problem with rise but everything was working fine on their end and they believe the problem is my router went into "bridge mode." So what can I do to fix that?
  • Hi Srminnehan,
    1. Are you are referring to the Internet light (planet symbol)?
    2. Please try using another Ethernet cable to connect the router to the modem.
    3. Please make sure that both ends of the cable are properly connected.
    4. You can also try doing a loop back test to check if the WAN port on the router is working. Check the link below for the steps.
    http://kb.netgear.com/app/answers/detail/a_id/28408
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Srminnehan,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Srminnehan,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
