rrsrer
Aug 17, 2017Follower
R6400 Lan Speed Gigabit
Hi All,
Before I go ahead and get new cat5e cables and begin tinkering with my NIC cards, and perform hard resets of the router.
Can someone tell me if my 4 lan ports on the R6400 support gigabit speed? I have two devices connected and they are running at 100mb
If it doesn't support gigabit, what is the next router in light will will provide gigabit connectivity to the lan ports
Thanks in advance
Sergio
> speed?
The User Manual says so. Go to http://netgear.com/support , put in
your model number (plain "R6400" or "R6400v2"?), and look at
Documentation. (Then look at the documentation.)
What are these "two devices"? How did you determine that speed?
1 Reply
> speed?
