k6
Dec 30, 2020Guide
R6400 Missing Firmware Update
Got the email about the important firmware update, but there are no updates available when I checked through the router page. My current firmware version says "V1.0.4.84_10.0.58," when I looked onli...
k6
Dec 30, 2020Guide
Anyone able to help with this issue?
Can't contact support since my router is older than 90 days...
- mtnroadsDec 30, 2020Aspirant
Are you unable to login to the router directly, from a browser, using admin? When I did that, I simply used the UPDATE function and it went out and found the correct update (listed above).
