k6
Dec 30, 2020Guide
R6400 Missing Firmware Update
Got the email about the important firmware update, but there are no updates available when I checked through the router page. My current firmware version says "V1.0.4.84_10.0.58," when I looked onli...
k6
Dec 30, 2020Guide
Anyone able to help with this issue?
Can't contact support since my router is older than 90 days...
mtnroads
Dec 30, 2020Aspirant
Are you unable to login to the router directly, from a browser, using admin? When I did that, I simply used the UPDATE function and it went out and found the correct update (listed above).
