bluemars's avatar
bluemars
R6400 Port Forward issues V1.0.1.12_1.0.11 Custom service rule conflict
I am getting the below error message when trying to build a new custom rule.   Custom Service Rule Conflict The new custom service must not conflict with any existing service rule.   I have two ...
  • bluemars's avatar
    Sep 07, 2016
    This work-around was applied in Firefox.
    Enable the debugger.
    Create the second rule, but instead of clicking 'Apply', right-click the 'Apply' icon and select 'Inspect Element' and edit the following in the debugger window to remove the text in bold:
    <button value="Apply" onclick="buttonClick(this,'Apply');if(!Check()) return false; Final();" type="submit" name="apply" class="button-apply"> <span class="roundleft_apply">Apply&nbsp;<span class="apply-icon">
    After editing the code, click the 'Apply' icon to make the changes.  This should then allow the rule to be added.
