sxrxrr
Jan 04, 2018Aspirant
R6400 router slow after firmware update V1.0.1.32_1.0.23
WiFi web download speed test dropped from near 100 Mbps download to around 20 Mbps after firmware upgrade. I tested by plugging directly into modem and get around 200 Mbps; same when cabled directl...
- Jan 05, 2018
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
sxrxrr
Jan 06, 2018Aspirant
The factory reset fixed it. Went from 20 down to over 200 down.
Now I know to do the factory reset anytime I upgrade the firmware.
Thanks!
michaelkenward
Jan 06, 2018Guru - Experienced User
That's good news.
A reset isn't always needed, but it is daft not to try it if you have the sort of problem that hit you.
Netgear could help by including that in the release notes, but some people seem to have an almost religious aversion to the idea.
