sxrxrr
Jan 04, 2018Aspirant
R6400 router slow after firmware update V1.0.1.32_1.0.23
WiFi web download speed test dropped from near 100 Mbps download to around 20 Mbps after firmware upgrade. I tested by plugging directly into modem and get around 200 Mbps; same when cabled directl...
- Jan 05, 2018
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
whitedp
Feb 05, 2018Tutor
Hello and thanks for this "fix". I have my settings data for the previous version backed up to a file on my wifi-connected computer. I sure do NOT want to re-enter everything. Will I be able to restore the settings from the file on my computer after I factory reset (which, by definition will wipe out my settings)?
michaelkenward
Feb 06, 2018Guru - Experienced User
You can try it, but it may reintroduce any problems that you see.
If that does happen, and the thing works fine before you restore the settings, then at least you will know that there is a fix that you can either use or ignore and live with whatever problems brought you here.
