sb123's avatar
sb123
R6400 slow internet
I am having extremely slow internet speeds thNetgearhe netgear router I just purchased.
the wifi and lan speeds are just crawling.  I replaced a 4-year-old router that was running much faster via lan and wifi.
Is slow internet speeds a known issue with this Netgear router?  Any ideas how I can fix this?  I have a job and a family so I don't have a ton of time to tinker around with my LAN.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi sb123,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • uzhgorodets's avatar
        uzhgorodets
        slow speed issue, a few weeks ago my router just started slowing download speeds down, i'm supposed to be getting over 100mbps and i do when connect directly to the modem but it slows down to like 5-20mbps when i connect my router, i'm connected via cat 5 wire, my Firmware Version V1.0.1.24_1.0.18, i don't know what the problem is.  i have the router for about 16 months now and it have been working great untill a few weeks ago
