avdavis58's avatar
avdavis58
R6400
I changed out my modem and have a default gateway address (my IP address changed) how do I configure a Port Forwarding or is there another way
  • plemans's avatar
    What modem/gateway do you have?
    Have you looked through the manual on port forwarding?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
    • michaelkenward's avatar
      michaelkenward
      And what do you really want to achieve?
      I can't tell from your message. People often talk about "Port Forwarding" when they really need to do something else.
      • avdavis58's avatar
        avdavis58
        I am trying to log into a server to get the IP address but lost the password, what can I do?
