packermans4's avatar
packermans4
Follower
Aug 31, 2017
R6400/AC1750 sudden drop in wireless speed
Have had an R6400/AC1750 running my wired and wireless cable (Medicaom) connections since 10/2016 with no issues. Did a firmware upgrade a few months ago with no consistent/obvious problems, although...
  • DexterJB's avatar
    Sep 05, 2017
    Hi packermans4,
    1. What is the firmware version of the router?
    2. Have you tried using a WiFi analyzer and changing the wireless channel?
    3. Does the issue persist on both bands (2.4GHz and 5GHz)?
    Dexter
    Community Team
