packermans4
Aug 31, 2017Follower
R6400/AC1750 sudden drop in wireless speed
Have had an R6400/AC1750 running my wired and wireless cable (Medicaom) connections since 10/2016 with no issues. Did a firmware upgrade a few months ago with no consistent/obvious problems, although...
- Sep 05, 2017
Hi packermans4,
1. What is the firmware version of the router?
2. Have you tried using a WiFi analyzer and changing the wireless channel?
3. Does the issue persist on both bands (2.4GHz and 5GHz)?
Dexter
Community Team
DexterJB
Sep 05, 2017NETGEAR Moderator
Hi packermans4,
Dexter
Community Team
DexterJB
Sep 12, 2017NETGEAR Moderator
Hi packermans4,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
