Gesh
Aug 22, 2023Tutor
R6400v2 drops wifi connected device
Hi guys, I have this router from 2018 and recently I started to have issues like every 1-2-3 days some of my wifi devices lose their connection with the network. After that if I try to connect them...
michaelkenward
Aug 22, 2023Guru - Experienced User
Gesh wrote:
After I started receiving this issue I tried to update the firmware to latest from the router page - V1.0.4.128_10.0.104
That is the latest firmware.
You say "tried". Does that mean that it failed?
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
1-2-3 days some of my wifi devices lose their connection with the network. After that if I try to connect them again - they are not able to connect any of the networks 2.4/5ghz but they see the network names.
What happens when you try to connect?
Have you tried the "forget and rejoin the SSID" trick for these mobile devices?
Have you tried playing with the wifi channels or looked for local interference?
I have seen a lot of other topic regarding same problems with no fix actually instead of buying new router not from Netgear, so anything that you could advice me guys?
I don't recall seeing a flood of messages here. Can you point us to some?
This is am ageing router (first version 2015), so there is going to be a lot of historic stuff there that may well be out of date.
- GeshAug 22, 2023Tutor
michaelkenward wrote:That is the latest firmware.
No, it is all good, it is with this firmware.
There is no such device, my router is directly connected to ISP switch in the basement of your building.
Devices tries to connect and after a while it simple says `can`t connect` and thats all. I tried once to forget the network from my notebook but problem still exist and I don`t see how it could be because of that since it happens on 3-4 different devices.
I tried before, will play around a bit more but one of devices is really 1 meter away from router so interferance should not be a problem IMO, but I will try.
A couple of similar or the same problems:
- https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Netgear-r6400v2-drops-wifi-every-few-days/td-p/2040941- https://community.netgear.com/t5/SMART-Wi-Fi-General-and-Legacy/Brand-new-R6400v2-drops-internet-connection-every-day/m-p/2215231
- https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Netgear-R6400v2-router-loses-internet-connection-daily/m-p/1995241- michaelkenwardAug 22, 2023Guru - Experienced User
One of those. That makes it hard, if not impossible, to diagnose what is happening. There aren't many people here familiar with those networks.
They all do their own thing and don't behave in the same way as a modems or ONT. It is really down to the people who run the system to tell you how best to connect things to it.
I really can not understand what you mean? How it is possible that device which provides me actual internet could be the problem that my WIFI devices is disconnecting my device?
It is not the problem that all connected devices can not open external sites /have internet and can ping google/ but the problem is that they are being disconnected from local wifi network.
