Pmiboe
Jul 01, 2017Aspirant
r6400v2 Router: Ready Cloud shown as offline when operated as Access Point
Hi,
my web interface at http://readycloud.netgear.com/ shows desvice as offline. ReadyCloud for Windows does the same (PC with Win7 connected to local LAN. The same is fpr Notebook with Win 10 connected via WLAN).
BUT:ReadyCloud App for Android on my Mobile is able to access the shares on the USB drive attaches to the 6400v2 via 4G Internet connection.
Is it possible that the web site and the Android App have different methods to access the USB drive?
What are my possibilities to make the web-interface work as well as the pc-software? I don't like to switch to Router Mode as the r6400v2 is situated behind a router provided by my ISP. Inbetween is another switch where several PCs are connected.
Peter
Hi Pmiboe,
1. What is the firmware version of the router?
2. Have you tried resetting the router and going the configuration?
3. For isolation, you can test if the persists when the device is in router mode.
Dexter
Community Team
