Pmiboe's avatar
Pmiboe
r6400v2 Router: Ready Cloud shown as offline when operated as Access Point
Hi,
my web interface at http://readycloud.netgear.com/ shows desvice as offline. ReadyCloud for Windows does the same (PC with Win7 connected to local LAN. The same is fpr Notebook with Win 10 connected via WLAN).
BUT:ReadyCloud App for Android on my Mobile is able to access the shares on the USB drive attaches to the 6400v2 via 4G Internet connection.
Is it possible that the web site and the Android App have different methods to access the USB drive?
What are my possibilities to make the web-interface work as well as the pc-software? I don't like to switch to Router Mode as the r6400v2 is situated behind a router provided by my ISP. Inbetween is another switch where several PCs are connected.
Peter
  • Hi Pmiboe,
    1. What is the firmware version of the router?
    2. Have you tried resetting the router and going the configuration?
    3. For isolation, you can test if the persists when the device is in router mode.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Pmiboe,
    Dexter
    Community Team
    • Pmiboe's avatar
      Pmiboe
      Hi,
      firmware is V1.0.2.32_1.0.20
      runs in AP mode, because the r6400v2 is situated behind another router (isp).
      Peter
      • Pmiboe's avatar
        Pmiboe
        After upgrade to firmware 1.0.2.34 the problem persists. Could it be related to AP-mode? But why does it work with the android app?????
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Pmiboe,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
