charlie9203's avatar
Jun 22, 2018
R6900P will not respond to ping from internet
Sometimes I need my R6900P router to respond to ping from internet.  So I temporarily check "respond to ping from internet" on Advanced/WAN Setup page.  It worked fine on firmware ver V1.2.0.22_1.0.7...
  • antinode's avatar
    antinode
    Jun 23, 2018
    > [...] However, I have not tried updating, factory reset, and reprogram
    > all setting from scratch.  In reading many issues, it seems doing that
    > usually does not solve the issue. [...]
       It should never be needed, but when actual behavior disagrees with
    apparent settings, it's worth a try.  If you save your old settings, and
    the settings reset doesn't help, then it should be easy to restore the
    old settings.
    > [...] When I revert to V1.2 above, the port forwarding starts working
    > again with no other setting changes.
       "ping" response and port forwarding are entirely different, but...
       Sounds like a firmware bug (of which there is seldom a shortage), but
    running the reset test is the most efficient way to determine whether
    it's a waste of time.
       Some of the folks here seem to recommend a reset to cure everything
    from bad breath to cancer, and then insult people who are less
    enthusiastic.  It should cost no more than some wasted time, and you can
    be pretty confident that someone will suggest/demand that you try it
    before proceeding.
