jkwinn26's avatar
jkwinn26
R6900v2 Failed Firmware Update-Corrupt
I tried updating my R6900v2 Nighthawk from V1.2.0.16 to 1.2.0.24 yesterday. After several failed attempts through NetGenie I tried via the Admin console(routerlogin.net). It again failed repeatedly, ...
  • jkwinn26's avatar
    jkwinn26
    Jun 26, 2018
    In leiu of writing an overly drawn-out post, I had hoped to make it concise and perhaps find someone who has had the same or similar experience with the R6900v2. But, if more detail is called for, then here it is.
    Well....going back through the 3 different articles/posts (first, second, third), I redid the last step in the 3rd post a couple times and viola! It eventually took.
    So to fix this issue, I did the following. I tried it once to no avail, did a power recycle and did the push on bootup and it worked.
    tftp -i 192.168.1.1 put R6900v2-V1.2.0.16_1.0.1.img
