jkwinn26
Jun 26, 2018Aspirant
R6900v2 Failed Firmware Update-Corrupt
I tried updating my R6900v2 Nighthawk from V1.2.0.16 to 1.2.0.24 yesterday. After several failed attempts through NetGenie I tried via the Admin console(routerlogin.net). It again failed repeatedly, ...
- Jun 26, 2018
In leiu of writing an overly drawn-out post, I had hoped to make it concise and perhaps find someone who has had the same or similar experience with the R6900v2. But, if more detail is called for, then here it is.
Well....going back through the 3 different articles/posts (first, second, third), I redid the last step in the 3rd post a couple times and viola! It eventually took.
So to fix this issue, I did the following. I tried it once to no avail, did a power recycle and did the push on bootup and it worked.
tftp -i 192.168.1.1 put R6900v2-V1.2.0.16_1.0.1.img
michaelkenward
Jun 27, 2018Guru - Experienced User
jkwinn26 wrote:
If I press & hold the reset button and cycle the power, waiting for the power LED to start flashing white before releasing the reset button, it just continues to flash.
A flashing white power LED is a sign that you are on recovery mode.
This means that the TFTP approach is not the same as the way you do things with a flashing amber LED.
That is why your solution worked.
Netgear really does need to write better notes on this issue. I only found out about recovery mode because I had to use it for some beta tests that required even more "magic" on the router.
