Jmccann6's avatar
Jmccann6
RB50 and new MacBook M1 - Constant disconnects / slow speeds
Just purchased a new MacBook M1.  I'm dealing with disconnects and slow speeds.  When this happens it appears that my Macbook is connect to the 2.4GHZ network.
I'm guessing I need to seperate SSID's so I have one 5GHZ and another 2.4GHZ.  I don't really want to mess with the main SSID. Can I change just the guest network to 5GHZ only?
Any other suggestions appreciated.
  • hi, did you ever get this sorted? Have same issue with brand new MBP M1 running latest Big Sur version.
    thanks
    • Jmccann6's avatar
      Jmccann6
      Hi, unfortunatly no.  I ended up buying a new TPLink mesh system and the disconnects have stopped.  Crazy that I had to buy a new router, but probably time to upgrade anyway.
      • MythicalLimits's avatar
        MythicalLimits
        I have an Orbi AX4200 triband wifi 6 Mesh and am running into the disconnected from internet while connected to the router issue pretty much daily.  I just got the M1 last week for work.  My previous work macbook did not have this problem.
        If anyone knows a fix for the router or the M1 that works, please let me know
