ClFan
May 29, 2021Follower
RBK50 — Orbi AC3000 Tri-band WiFi System - Use of extenders
Hello, I have a Orbii AC3000 (RBK50) with one satelite. I want to extend the range in the house by using a wall plug in extender. When I use an extender and I assign the same name to the extender so that it acts like a satelite and we don't have to have devices select a different WiFi name? Thank you.
1 Reply
You can do that but it might not function like the orbi system as they don't integrate like an orbi satellite.
The EX7500/EX7700/EX8000 work fairly similar. The other extenders do work but again, they probably won't roam the same.
There is an orbi plugin that is compatible. The RBW30
