Rhmorgan67's avatar
May 01, 2021
RBR850 3.2.18.1 - No communication with ISP, drops every 2 hours
In January 2021 my RBR850 updated firware to version 3.2.16.22. Every two hours my router would disconnect and I would have to unplug, and reboot. I checked with my ISP and every 2 hours when their server checked-in with my router - the Orbi didn't respond - so it dropped. I manually installed the old firware, 3.2.16.6_1.4.4 and everything turned back to normal. I have been using that firmware since January with no issues whatsoever.
Yesterday my RBR850 automatically downloaded the new firmware version 3.2.18.1 and my service began to drop every two hours again. I manually loaded 3.2.16.6_1.4.4 and it everything functioned normally. However, the new firware update, once again, automatically loaded in the middle of the night - and now it disconnects every two hours again.
Why is the new firmware version being forced on me? Is there a way to stop it from loading? The issue is with the new firmware, no doubt. Something is not right with it and is causing the router to NOT reply every two hours with my ISP. Something changed after 3.2.16.6_1.4.4. How can I stop 3.2.18.1 from loading automatically?
  • Have you looked under the Advance  -> Administration -> Router Update in the router configuration app and disabled the auto update feature?  That should prevent the update from being applied automatically.  That is where it is found in my configuration.
    • Rhmorgan67's avatar
      Rhmorgan67
      Guide
      I've been on with Netgear support, we did a factory reset of the modem and the little box does not exist on my screen. There should be a box that says, "automatic updates" or something like that, but there isn't. They said when first setting up the router, I may have chosen auto updates and so the box disappeared, but doing a factory reset should have made the box return - but it didn't. They are now supposed to call me back in 2-3 hours...
      • No1Mportnt's avatar
        No1Mportnt
        Luminary
        Not sure why the box is not there but I do know on mine you can select your choice and the other selection is still there.  Hopefully, they will have the answer when the call you back.
