phillie's avatar
phillie
Can not find Individual time restriction option for each wifi device on wifi network
I just installed my NETGEAR AC1750 Smart Wi-Fi Router, 802.11ac Dual Band Gigabit (R6400-100NAS).  My main purpose of buying a wifi router was to set up time restrictions for my kids devices.  I've l...
  • DexterJB's avatar
    DexterJB
    Oct 21, 2015
    Hi phillie,
    As suggested by Retired_Member, you may perform address reservation for the devices that connect to your network then you can setup a schedule for blocking all service.
    How to setup address reservation:
    1. Make sure the devices that you want to manage are already connected to the network (wired or wireless).
    2. Access the router UI. You can do this by typing www.routerlogin.net or the IP address of the router and login.
    3. Select Advanced > Setup > LAN Setup
    4. Under Address Reservation click on Add
    5. Select the device that you want to assign a specific IP address to and remember that IP address.
    6. Click on Add. The device should appear on the table with the specific IP that will be assigned to it every time it connects to the network.
    7. You can perform the same steps (4 to 6) to add more devices.
    Once you have completed the address reservation, you can then setup a schedule then block services.
    1. Still under the Advanced tab, select Security > Schedule. As it stands, you can only create a single schedule.
    2. Setup your preferred schedule for the day/days and time frame then click on Apply.
    Once the schedule is setup, you can block the services.
    1. Still under the Advanced tab and Security, select Block services.
    2. Select Per Schedule then click on the Add button.
    3. Select All for the Service Type.
    4. Select Only this IP Address then specify the IP address of the device that you want to block on that schedule.
    5. Click on Add. The IP should appear on the Service Table.
    Dexter
    Community Team
