RalfyM
Apr 28, 2017Guide
Is there a device for my needs?
Hello, I'm throwing good money after bad at the moment to get a particular setup. Without boring you with the details this is what I'm after: 1. A LAN extender with Wifi so I can connect to my n...
- Apr 29, 2017
RalfyM wrote:Thank you for the quick reply. The R6400-100UKS is within price range, the R7000 is just slightly out. This model can answer requirements 1, 2, 6 and 8. But as I'm finding with most advertised specs there is no information on USB hub support, supported HDD sizes and of particular importance having a static, unchanging name to each drive including after a restart.
Netgear does publish a list of compatible USB drives:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
But it may not be up to date, or even that reliable.
If you crawl around this place looking for conversations about Rapidshare you will find that the general view is that Rapidshare is a poor way of sharing stuff over a network. Not just for compatibility reasons, but because it is not really designed for that purpose.
AS William10a says, most of the real experts around here advocate using genuine NAS boxes. There is no such thing as a "router with NAS capabilities". USB is not NAS. NAS is storage that you connect to over the LAN not through USB. It is more expensive, but you get what you pay for.
If you want to extend wifi coverage to the far reaches of your mansion, the wifi capable Powerline devices might be a good option.
RalfyM
Apr 28, 2017Guide
Regards
michaelkenward
Apr 29, 2017Guru - Experienced User
