LoadedferActon_
Nov 22, 2020Follower
re: old router
Hello All,
I used a Netgear N750 Dual Band Router, Model WNDR4300V2. Now I've changed it for a new one. Is the old one safe to recycle, sale, or should I just trash? Don't want any possible secrecy or data in any manner to be available to the malware-oriented users. Thanks for your input. LoadferActon_
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
That will eliminuate any personal details.
- wcalifasProdigy
If it still works you can list it on ebay. You can reset it by pressing the reset button for 30 seconds with a paper clip and it will go back to default settings. List it on ebay and sell it for cheap maybe someone can use it if its still good.
