grfromtx
Jun 27, 2016Aspirant
Remote Management vs Remote Access
Disable remote management 2016-06-27 03:10 PM If the box for remote management is not checked, does that confirm that the router cannot be accessed remotely? Urgent reply needed as I am ...
- Jun 27, 2016
Not necessarily. It's talking about legit remote access/management. Malware, Virus type can intrude your router specially when you are using
public hot spot like at an airport.
VE6CGX
Jun 27, 2016Master
