rajandmk
Jan 21, 2018Aspirant
Unable to use actual Internet speed on a Netgear Router.
 Hi all,  I have a Netgear WNDR3700 gigabit router and a gigabit internet connection where I live. I get two different speed when I check my internet using speedtest.net in following two cases.     ca...
- Jan 21, 2018Just because it has Gigabit Ethernet ports doesn't mean that it can forward packets between them at Gigabit rates. My 10 year old PC has a Gigabit port but it can only handle about 600 Mbps.
rajandmk
Thanks for your reply. I planned to get a new AC1900 router soon. But since this router is a gigabit router, shouldn't it handle gigabit LAN connection without the problem? (considering all the features that'll disable hardware acceleration mentioned are disabled)
TheEther
Jan 21, 2018Guru
