Identity's avatar
Identity
Wireless turning itself off
Hi,   I have searched for this on the forum already and, while other people are experiencing random loss of WiFi, none of their symptoms mach what I'm getting.   I have a Netgear N150 Wireles Rou...
  • Babylon5's avatar
    Nov 16, 2015
    Is there anything in the router log which might relate to this? Perhaps the router is accessing the NTP server at these times and setting its clock, if so a scheduled time setting start of 00:00 may be the reason for the temporary loss of WiFi. If you set that start time to 00:05 for example then if it is a time related issue the problem may disappear.
