Bengt7jqb
Oct 20, 2017Aspirant
WNDR4500v2 E-Mail port number
How can I define the port number? Cant find a spot to use here
- Nov 08, 2017
The model has been considered EOL for awhile now and there will be no future firmware enhancements that will be released.
michaelkenward
Oct 21, 2017Guru - Experienced User
If it isn't available already, that isn't the sort of thing that new firmware is likely to add.
On my device it is in:
- Advanced
- Security
Bengt7jqb
Oct 21, 2017Aspirant
But there are no space for port number
- antinodeOct 21, 2017Guru
> Can't (yet) see the picture. A plain-text description might appear
> sooner.
Still true.
Huh? Is there a place to put the Mail Server name/address? Can you
add ":587" to what you have there now? It's not complicated.- Bengt7jqbOct 21, 2017Aspirant
add ":587" to what you have there now? It's not complicated.No I try pop.server.com:587 and its not a good e-mail
It seems not posibal
Mybe it try to send on 25 and this is blocked
