naveen555's avatar
naveen555
ReadyDLNA not showing files
Hi
ReadyDLNA used to work on my router. I recently changed the folder structure and also upgraded the firmware to the latest one (V1.0.4.8_10.0.77). Now the files can be seen using a computer file browser and I can transfer files across, however, I cannot see any media using a media browser (like Roku or Sony TV's media browser).
How do I fix this problem?
thanks
Naveen
  • Hi naveen555,
    Please try using the default settings and check if the issue persists. You can also try reconfiguring the router instead of re-loading the config file.
    Dexter
    Community Team
